Relliott6879 - For smooth plastics, like the ones on the dash, you would rub down the plastic to provide a good "KEY". Then build up a number of layers of primer. Then rub down with 1200 or 1500 wet and dry paper so it feels glass smooth. Then you would paint. Again you would build up a number of layers before rubbing down again with 1200 or 1500 wet and dry. If it's a mettalic paint, it will make the paint go very dull and almost matt. This is correct and needs to look like this for the lacquer to do it's work. The finish should again be glass smooth. Then build up a couple of layers of laquer. I then go over the laquer with some very micro fine polish which smooths the laquer down to give it it's extra shiny finish.
If you are painting other more textured pieces like the A, B and C pillar covers, once painted with lacquer, I don't do any final polish as there is no point. You also wont get each layer glass smooth for obvious reasons.
Scunnycougar - The items I have used for this are listed below:
DAS-6 Dual Action polisher
Menzerna Power Gloss Cut 5
Menzerna Intesive polish cut 3.5
Menzerna Super Finish cut 2.5
Menzerna Final Finish cut 1.5
Menzerna coumpounding pads
Menzerna polishing pads
Menzerna finishing pads
PoorBoys Black Hole Glaze
DoDo Juice Purple Haze wax
Chemical Guys Maxi Suds II
Chemical Guys Strong Wash
Meguiars clay bar
Meguiars quick detailer
Premium Blue Rim and wheel cleaner
Poorboys natural look dressing
Meguirs PlastX
303 Aerospace protectant
Gliptone Liquid leather cleaner
Gliptone Liquid leather conditioner
Carlack glass sealer kit
Meguiars Gold class trim detailer
Various sponges, a number of microfibre towels, wet and dry papers, detailing brushes (for all the hard to reach places), Dyson cleaner, Karcher power washer and a Hometek steam blaster.
I "think" that is everything :eek6:
Sabre Tooth - I get where you are coming from but must disagree about the difference on re-sale value. If i had just washed it with normal car shampoo and polish, not only would I be hard pressed to find anyone that would buy a Cougar with such bad paint (when there are so many out there to choose from), but there is no way in hell I would be able to ask £2k for it. I mean, look at the "before" pictures. Would you spend £2k on a Cougar that looked like that, even if mechanically it was 100% sound and with less than 50k miles on the clock?
Ace Melon - Sounds good to me. Just confirm a date nearer the time and I'll make sure I book the time off work. If the weather turns out to be poor, I have just secured use of my sisters father in laws double birth car garage. He lives 1.2 miles from me, and it has power, lights and even a great big 80's hifi
Heck, he even has a snooker table and a small pool for the end of a hard day cleaning
No progress on the car so far. Postman doesn't get to me till just before 1pm :incazzato:
