M
No i haven´t got any drafts...
Only problem I can see is the OMP strut braces usaly have an adjuster bar (a twist lock/nut type set up) in the middle so you can adjust the length of the center bar, you may find if you remove it at any time in the future that you wont be able to re-fit it as the bodywork will flex back into shape and the distance between the struts will be slightly out. I think Shywaz just wanted a blue-print so he could make his own upsorry maybe i can´t understand you... it´s quite easy do it, but i don´t know, if this bar works like original (OMP etc.)... i made it with style ,,trial and error,,
marekThis strut brace is from my garage... I spent for it about 6 hours of my free time and 20euro from wallet yes I´m not from UK and I think it could tell from my English
nice seats mate what they out ofnew seats... better than original
Only thing Ican think of would be a threaded bolt with two nuts and then cut a thread into each end of the main center shaft (after cutting it in half) then threading this threaded bolt into each end, I'm guessing thats how omp do it? My Freedom designe strut brace has adjustment at each end by the strut mounts.exactly Matt i almost figured how to do it, but i cant find adjuster mechanism anywhere...
pity steering wheels on the wrong side though
