Cheers Bobster after a lot of meesing about glueing cutting bending bit of pipe this is what i have ended up with and i think it works.Biggest problem is the Auto gearbox mounting bracket by trying to put a pipe to it you restrict the air flow and you havent got much room under the battery tray to put a decent size pipe.Also there is a block connector into the gear box which could get in the way.It does seem to work.Once again cheers Bobster for putting the photos on how???
